MIB238 Card
MIB238 Card
Eric Pearson recently announced on Facebook that he has developed a modern drop-in replacement for the legendary MIB3 card. This is truly some great news as its likely the most versatile expansion card ever created for ADAM.
He has generously released his MIB238 as a DIY project available on GitHub. Unfortunately I don't have the skills to do it myself but if anyone out there who does would be interested in building & selling I'd be interested in buying one!
Re: MIB238 Card
I do have an Orphanware/HLM-GMK side expansion box that adds a serial port. For some reason it has recently stopped working for me though. I'm not sure if its an issue with my expansion port or an issue with the device itself. When I go into ADAMLink V terminal mode now it just echoes a few characters like "DDDDDD" and then reports "Carrier Lost". I've tried cleaning the contacts but it didn't help.
Re: MIB238 Card
Ok, I'll give quick term a try.
I am connecting it to a WiModem232. Everything was working flawlessly until last week. I did install my SD-DDP drive last week but I have also since tried removing it and I still have the same issue with the serial port.
Re: MIB238 Card
Same results with quick term. Just a bunch of repeated "D" characters...
- Attachments
- Qterm screenshot
- JPEG image-B02B877122D7-1.jpeg (483.45 KiB) Viewed 4287 times
Re: MIB238 Card
First you have to set the baud rate (Esc B). And how is it hooked up? Null Modem? or ?
Milli
Re: MIB238 Card
Setting the baud rate made no difference. This happens no matter whether I have the serial cable connected to the WiModem or nothing at all. I don't have a null modem cable.
The even stranger thing is that I still get the stream of D characters even if I don't connect anything to the side port! This leads me to believe it might be an issue with my expansion port and not with the serial device. Maybe I knocked something loose when installing the SD-DDP? Not sure how that could've happened as the installation went smoothly and worked first try but I guess its a possibility.
Re: MIB238 Card
That is possible - There was a post today on facebook of someones system dieing and they have the SD-DDP plugged in - you should post this on FB also - it definitely is not your serial card if its unplugged and the expansion port has nothing to do with the keyboard - the SD-DDP does since it goes through the master 6801 just like the keyboard does.joltguy wrote: ↑Thu Nov 05, 2020 11:06 amSetting the baud rate made no difference. This happens no matter whether I have the serial cable connected to the WiModem or nothing at all. I don't have a null modem cable.
Milli
Re: MIB238 Card
I know most people on here are likely on the Facebook group too but just in case: John Lundy has built a few of the aforementioned MIB238 cards and is offering them for sale
https://www.facebook.com/groups/1155310 ... 9174907845
Already ordered mine!
